Worked on F14-07R and 14-07L today, left and right hand rudder pedal angles. I finished the right hand angle but the left hand angle has only been cut and drilled, it still needs final finishing. These are the first of the longer angles to make. I started with all the shorter angles because if I make a mistake on those, I know I will still have enough raw angle to remake them and not have to order new pieces. Now that I have a bit of experience, I'll start making the longer ones.
