Started working on the main root wing attach angles, W20-02 and W20-03. 2 are required of each so 4 parts in total. I drew the templates in AutoCAD today, printed and cut them. The W20-02 angles need to be opened to 93.9 degrees and the W20-03 angles need to be closed to 86.1 degrees so I did this first before cutting. I then spray glued the templates on and started cutting out the exact shape with the bandsaw. That's all for now clocked about 2 hours today, I'll try to finish these angles tomorrow.
