This is a little project I've been working on on the side, improving the Sonex standard vents. The standard vents are known to be very ineffective because they don't have any side walls so I designed a vent to fit on the standard cut-out and had my friend print it on his 3D printer. No need to explain how they will work, the pictures should be pretty self explanatory.
