Today I finished installing the canopy bow screws, I then installed the aluminium rivets in the hinge and side strip. I used my air riveter for the job, I know some use a hand riveter for the job to be "safer", I don't believe it is "safer", the stem will break at the same pressure. Anyway, I just set the pressure real low (10-15PSI) and did a couple of test rivets first in a scrap piece of plexiglass.
