Brief Description: Making the rubber seal attach doublers
The rubber seals are attached to the fence baffles using doublers. The AeroVee fence baffle kit does not include these pre-cut, you get a piece of 0.032 aluminium sheet and a set of full size templates. So before you can attach the rubber seals, these have to be made, which is what I did tonight.
