I made the oil cooler baffle assembly today, there is very little information available on how to do this. The plans call for a deflector to be made etc but no drawings exist. Luckily I'm not the first to have done this so some searching and asking around quickly gave me enough info to do the job. The deflector has a cut-out in the centre to clear the bottom aft centre stud and bolt of the case and the oil cooler has to be modified as well to clear the oil drain hole.
