The exhaust tunnels require "lips" to deflect the air away from the tunnels and create an area of low pressure sucking the hot air out of the cowling. There's also no drawings on how to make these but the requirements are for the lips to be 1" long and at an angle of 30 degrees in the air stream so with this information it was very easy to draw those up and cut them out.
