Brief Description: Rear spar carry though assembly
In preparation for wing rigging I started working on the rear spar carry though assembly. I had made all the parts before but they now need to be assembled. Also, the channel was made for the standard seat configuration with the hole for the pushrod offset to the left, I have since decided to go with the lowered seat setup which means that hole needs to be in the center of the channel so I made an extra hole in the center. I don't believe there is any structural issue with having holes for both the standard and lowered seat configuration. After that I installed the fittings onto the channel, I still need to make the shear angle from the Z02-03 angle stock though.
