One thing I nearly forgot about is the pitot static assembly which will need to go onto the forward skin. I decided to make the assembly and the tubing support plates now before I disassemble the wing again and my working table is cluttered with wing skins. I should have made and installed the support plates before installing the forward ribs, it will be a bit of a challenge now to get those installed in the ribs but I'm sure it's doable using my angle drill.
