Brief Description: Bending the leading edge wing skins
Bent one of the two leading edge wing skins today, how easy was that, the vacuum method is great. It took a bit of time making sure the skin was centered correctly. After that you need to pull the edges together initially with some masking tape, finally it's just a matter of taping the plastic sheeting together and finally sucking the air out with a vacuum cleaner. Simple, nothing to it, I was impressed. I will make a video when I do the second one to demonstrate how easy it realy is.
