Brief Description: Finished rivettng the left main spar
Finished rivettng the left main spar tonight, on to the right main spar. As you can see from the pictures, the primer gor scratched (badly) here and there on the spar, I think there is no way around this when rivetting using the bolt and hammer method. You move turn the spar around so much it's just going to happen. When I prime the parts of the other spar I will pass over this one to touch up the areas where the primer has been damaged.
