Brief Description: Completed engine mount installation
Tonight I completed the engine mount installation, it was just a matter of putting it back on the fuselage and installing the screws. I used duralac in between the spacers and mount attach plates and also around the screws to prevent galvanic corrosion. The bottom screws in the lower attach plates need to be trimmed a bit because there is interference with the mount itself otherwise.
In the mean time the new piece of phenolic arrived so I can now get back to the rudder pedal installation.
