Brief Description: Drawing the lower firewall in AutoCAD
As with most other parts I had to make from scratch I decided to draw the lower firewall in AutoCAD, plot it at our large scale plotter at work, and then stick it to the stainless steel sheet with spray adhesive. If you have some basic AutoCAD skills, this is much easier, quicker and much more accurate (provided your plotter is well calibrated) than measuringdrawing directly on the metal.
