Brief Description: Attaching the pushrod support channels
I drilled and clecoed the pushrod support channels to the cross tie channels tonight. I'm building my Sonex with the lowered seat option so these go centered rather than offset to the right. I found the easiest way to attach these was to first mark the center positions on the cross ties, then take the whole cross tie and vertical channel squares off so I could work on the table, after that it was easy enough to attach the support channels and but the whole assemblies back on the tailcone box.
