Brief Description: Remaking aft lower fuselage skin and drilling long
Finished remaking the aft lower fuselage skin, this was rather easy using the other as a template. I will still need to drill the inspection hole and opening for the rudder cable though. I also bended the end of the skin again to 14 degrees and drilled the 2 longerons to the skin. I am back where I was before I found the error in the width of the skin.
