Brief Description: Starting on the right AFT fuselage panel
Started on the right AFT fuselage panel tonight. I first bent the edge of the skin to the required 14 degrees (I might have overbent it ot 15-16 degrees but I can easily fix that up later). Then I laid out the lower longeron on the skin and clamped them together.
