Continued fitting the tips. As many builders before me, I finally decided the tail tips do not fit well enough to slide between the skin and outer rib so like all those builders before me I decided to slide a piece of .032" metal between the skin and rib instead and attach the rib this way, much better fit. I completely fitted the left rib, dilled to 3/32", still need to complete the right rib though.
