Brief Description: Elevator horn assembly continued
The anchor nuts required to finish the elevator horn assembly finally arrived today so I got straight in to it and drilled/countersunk the holes for the nut in the assembly. I also primed the bare steel after that and I will probably also use duralac for extra protection of the steel. Finally I'll be able to finish the elevator assembly.
