I took the LH skin back off the H-Tail to bend it a bit more, I found there was too much force required to pull the skin against the ribs, even the clecoes were not able to keep the skin tight against the tip rib, after a bit more bending it fits much better. I did the same to the RH skin and attached it to the skeleton, did not finish this job tonight though, needs a few more holes and clecoes on the bottom side, I'll do those tomorrow night.
