Tonight I bent T12-07, the horizontal tail forward attach fitting. It went really well, I'm getting quite good at these bends. I used the same method I used for T06-03, V-block, 1" pipe in the vice, this resulted in a perfect 35 degree bent with a 1/2" radius. With this last bend I've completed all the .190 thick flat parts, on to the .063 thick parts (there aren't many).
