These are the last pieces that were originally made at the wrong thickness (.125 instead of .90) and had to me re-made. F14-10, gussets that go on the forward fuselage side panels. Fairly easy pieces but there are just a lot of them, 12. I found the easiest way to make them was to use a .125 piece as template which was drilled and clecoed to the 0.90 thick plate with 2 holed, then the remaining holes were drilled and the shape was drawn.
