Borrowed a set of longeron bending dies and accomplished the task of bending the longerons. Mounted and drilled the longerons #40 to the side skins. Turned the structure upside down on the bench and verified it was flat and level. Installed the belly skin and gussets and drilled everthing to #30 except the longerons. Good progress!
