Installed nut plates to anchor the hinge pins for the left side ailerons. Bent the pins for the hinges.
Moved the right wing back to the shop from the hanger. Began installing the right wing tip extensions and riveted them on. Just need to fit the plastic pieces for the tips and both wings will be ready for paint.
