Finished installing the left wing tip. As I have found the double sided tape does not hold the tip stiffeners very well I used JB Weld and glued them to the tips. This way they do not fall off as you try to rivet them. Started building a set of wing racks as well as a fixture to hold the wings while they are being painted.
