Phils Web Site
S-19
Verticle stabilizer and misc.
Mounted the vertical stabilizer. We had to shim the rear spar with .050 spacer. Attached the rudder in order to trim and rivet the plastic vertical stab tip.
Drilled a hole in the instrument sub-panel for the power outlet and finished wiring it.
Vertical stab and rudder
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
