Spent a couple hours working on details. Modified the opening on the bottom cowl around the nose gear leg. This was needed so the cowling could clear the three blade prop when being removed. Also enlarged the cooling opening for the rediator/oil cooler. Began threading the push rods for the autopilot. Began mounting the verticle stabilizer.
