Finished most of the wiring firewall forward. Had an issue with the power to the relay for the aux alternator. Found that I had not actvated the curcuit in the VP-X. Temporarily installed the prop in order to check the fit of the upper cowling (and to see how it looks!!!). I decided to go with a Sensenich three blade as it will be a little smoother and quieter. It also looks better:)
