Continued the firewall forward installation. As I purchased an older carbuator air box, the support fitting is in a different location than the newer ones. Because of theis a stock air box support will not work. I fabricated a new support from .090 aluminum. Mounted the fuel pressure sender to the firewall. Continued working on the wiring for the engine and charging systems.
