Continued on the plumbing, wiring and controls. Completed hooking up the throttlr and choke cables. Finished the radiator plumbing. Received the carb heat muff from Rans and installed on the end of the muffler. Continued working on the engine wiring routing as well as completed the battery/starter/ primary ground wiring.
