Phils Web Site
Date:  3-2-2014
Number of Hours:  6.00
Brief Description:  Pitch servo, ADAHRS and ADSB antenna
Did a bunch more wire bundling. Installed the ADAHRS mount we had fabricated some time ago. Ran the pitot and AOA lines from the front where they will connect to the wing. Ran the static lines to the rear where I expect to mount the vents in the sides. Installed the pitch servo and shortened and terminated the harness from the front. Added a doubler for the ADSB antenna to mount to. Installed the ADSB antenna and terminated the coax.
ADAHRS, pitot, AOA and static lines
Autopilot pitch servo
