Finished the pitot tube mount and installed the inspection reenforcement ring in the wing I will wait to rivet the inspection cover/pitot mount untill the wing is riveted and plumbed.
Mounted the fuel level sender in the tank. Built a wooden frame to support the tank and filled the tank with gas to leak check and to expand the tank. So far no leaks!! Will let the tank sit for a couple of days to make sure it is leak free.
