Bent the right torque angle for the right wing lower fuel tank skin to match the lower surface. Marked the center line, cut to length and shape. Match drilled the angle. Removed the anglr, deburred and riveted to the tank skin.
Did a little work on making the fuel line for the right wing. I decided to use stainless braided PTFE hose from the tank to the Andair fuel valve. This hose ie pretty much impervious to all chemicals in any type fuel and also has unlimited life.
