Made new leveling blocks and flipped the wing over to install the top rear skin. Set the skin in place and clecoed the trailing edge. Ran the wires for the fuel level sender. Should have drilled the holes for the snap bushings befor I mounted the inboard ribs, would have been a lot eadier. Will make sure I do the on the other wing. A friend reminded me I did not have any pictures of me proving I am doing the build so I included one. Thanks Bill!
