Phils Web Site
S-19
Fuel flow sensor
Worked on installing the fuel flow (red cube) sensor. Made a bracket to mount it on the cockpit floor between the rudder cables. Bent, flared and installed an aluminum fuel line from the sensor to the firewall bulkhead fitting.
Fuel flow sensor
RV9 Home
S-19 Home
2070
Ailerons/Flaps
Final assembly
Firewall forward
Fuel system
Fuselage center
Fuselage forward
Fuselage rear
390
