Brief Description: Started fabbing aileron push rods
I started fabbing the aileron push rods W-716 and W-818 that will actuate when you move the stick left or right to put the airplane into a roll attitude. Each 1.25" diameter aluminum tube was cut to length with the horizontal band saw and then deburred. I can only find three of the needed four rod end bearings needed for the push rods.
