Garys RV-7 Builders Log
Date:  4-17-2011
Number of Hours:  3.00
Manual Reference:  7-11
Brief Description:  Dimpled, cleaned, primed L flap parts.
Today I finished dimpling the left flap components. The Big D wouldn't work for the top skin so I ended up using the Cleveland C-frame that I bought from Randy when I bought the wing kit. Colten helped hold the skins while I held the other end and hit the die with the hammer. It worked good.
Next, I deburred all of the parts and cleaned them with MEK. I then primed all of the parts and skins with Duplicolor primer. Next session I will be able to start riveting the L flap together.
Dimpling the top skin with C-frame
Primed bottom skin, ribs, and spar.
Primed parts......
Primed parts......
