Garys RV-7 Builders Log
Date:  4-13-2011
Number of Hours:  1.00
Manual Reference:  7-11
Brief Description:  Match drilled bottom flap skins to ribs
I fabricated several small shims out of .025 to fill the gap between the aft end of the flap ribs and the bottom skin "spar" per the instructions. Next, I match drilled all the bottom skin to rib holes. After that I located and match drilled the piano hinge to the flap spar and skins.
Shims between rib and skin spar.
Match drilling skins to ribs.
Match drilling flap hinge to spar.
