Brief Description: Finished L leading edge riveting
Tonight I finished riveting the left leading edge spanwise rivets with the squeezer. This is a mini-milestone as I haven't finished riveting a component in some time. It turned out good and I started prepping the right leading edge by using the debur bit to dress the spanwise rivet prior-dimpled holes. I then installed clecos in every other hole.
