Garys RV-7 Builders Log
Date:  10-15-2010
Number of Hours:  0.00
Manual Reference:  SafeAir1
Brief Description:  Tubing kits and misc tools from Avery arrived
When I got home today a box from Avery's was at the door. It contained the install kits from SafeAir1 for the Dynon pitot tube (green tube) with angle of attack (AOA) (blue tube). I also ordered the static air kit (white tubing). These kits contain all the needed fittings to connect everything all the way to the instruments in the cockpit. All I will really use now is the tubing and snap bushings and a few of the fittings.
I also ordered an offset rivet tool because it was on sale, not sure where I will need it but it looks handy. I also bought a fastener holder for hard to reach places like holding the washers for the control surface installation. The other tool is for adjusting rod end bearings without damaging them.
Picture 3 shows the remote compass mounting bracket that come to find out, I can't install until I have the EFIS (electronic flight information system) which gets installed in the instrument panel. I might be retired by the time I actually need this. Oh well, it was only $14 I think.
I should be able to get some time this weekend to work on some of this stuff.
SafeAir1 Pitot, AOA, and Static air kits.
Offset rivet tool, fastener holder, rod end bearing tool
Dynon remote compass mounting bracket
