Brief Description: Bent both inboard and outboard tabs on trim tab.
Today I finished making the wood blocks and bent the inboard and outboard tabs of the trim tab. I took my time and they turned out pretty good. This is the type of process where you learn from the first one and the second piece could be very good. Unfortunately the RV-7 only has one elevator trim tab, so pretty good will have to do. It will function just fine, cosmetically it could be a little better, though.
