Brief Description: Installed split collars, bushings and springs for
Today I installed the nylon bushings, springs, and set collars on the master cylinder shafts. I then used the belt sander to trim the rudder pedal tubes to the proper length. Next, I mounted the master cylinders and they are looking really good.
Next session, I will drill the holes in the pedal brackets to mount the bottom of the master cylinders.
