Vans shipment of Cherry Max assorted rivets, AN3-4A bolts and washers arrived. Today I installed the remaining (6) bolts for the right fuel tank attachment to the spar. I torqued all of the bolts to 25 in-lbs.
I also drilled out and replaced a bad rivet on the L wing top outboard skin. Then I clecoed the R wing top skins on. Tanner worked in the shop doing math fractions.
