Brief Description: Riveted flaps and determined flap angles
In my previous construction, I had not put any rivets in the entire length of the bottom trailing edge of the wing. So tonight I added 180 rivets to secure the flaps and close up the wing. In addition, I checked the flaps angles for every increment on my LED indicator. Because you get to a slightly different point of travel when going down or coming up, I've included the range for each stop, by degrees.
1 = 0 degrees 2 = 0.8 to 1.1 degrees 3 = 2.3 to 3.7 degrees 4 = 4.4 to 5.3 degrees 5 = 6.4 to 8.0 degrees 6 = 9.2 = 10.2 degrees 7 = 11.0 to 12.6 degrees 8 = 13.4 to 14.6 degrees 9 = 15.7 to 17.1 degrees 10 = 18.5 degrees
