Brief Description: Added nose rib and started fitting fuel tank
I added the short nose rib angle and extra nose rib on the left wing. I then drilled and riveted the bottom skin to the rib. Added cork to the sides, back and bottom of the tank. Next I tried to locate the fuel tank drain and vent openings in the bottom skin. Not as easy as it seemed at first. I ended up having to enlarge the holes more than I like, so I'll be looking for a good way to improve the holes, cosmetically. Also, I have to do more adjusting to get it to set down in the opening more completely.
