Larry Winger's 601XL Project
Date: 11-4-2007
Number of Hours: 6.00
Brief Description: Installed right wing landing light & made pitot mo
My goal for the weekend was to finish all the exterior work on the two wings. I'm very, very close. I was able to complete the right wing landing light in record time. It only took about 3 hours to install, thanks to a template I was able to make from the other wing. I was also able to lay on the ground under the wing (on sawhorses), which made it much easier to cut and drill. The last item is the pitot mount, and I would have completed the whole thing, but I dropped a solid countersunk rivet for one of the nutplates. After spending too long looking for it, I gave up. I've written Warren Gretz, and hopefully he'll send me a few. It was my first chance to use a solid dimpler, and the dimples for thje #8 screws came out really well. Of course cutting out the skin for the mast to pass through was tedious, but the result was good. Now all I have to do is set the missing rivet, prime and rivet the backing plate to the access cover, and lightly grind down the pitot shaft to slide into place. I don't think that will take longer than one hour...but it will be down the road since I'll be waiting for the rivet.
Right wing exterior work done!
Pitot mounting mast in place and ready to rivet...almost
