Brief Description: Formed 2nd rear channel and misc.
Since I got the three large sheets for my wing skins yesterday, I now had the opportunity to take a 180mm slice off the top of the leading edge sheet to create two 6 foot rear channels. I did and then formed two new ones. One of those was a good match for the odd channel I made last night, so I got my other acceptable set. Because I made six half sections to get the four I needed, I had two discards. The good news is that I also needed to make the wingtip top and bottom angles (6W9- 6 & 7) which I was able to do from the material in the reject rear channel pieces. It took a little longer than starting with new material, but it sure made me feel a lot better about those two rejected rear channels. They live to fly another day!
Long view of the two rear channels before splicing
Miscellaneous parts, including the wingtip bottom and top angles (bottom right)
