Larry Winger's 601XL Project
Date:  8-12-2007
Number of Hours:  1.25
Manual Reference:  6W5-2
Brief Description:  Test nose rib
Well, I decided to tool up for nose rib production. The first step was to drill the 3/16" tooling hole near the front tip and then run to the hardware store for an appropriate bolt/nut/washer combo. I then carefully marked my first rib (7 left). When I saw that the plans called for a 4mm radius around the front tip, I was skeptical, given my past experience with the horizontal stabilizer nose rib. I decided, however, to give the designer another chance on this part. That was a mistake that will cost me one extra rib. In the "Scratchbuilding Basics" DVD, Mark and David advise that you need to grind it down to 2 or 3mm so you won't have extra material that has no place to go. Seems they were right again! These are not hard parts to make, so after making this adjustment, I expect I'll be able to mark, trim, file, smooth, clamp, bend, drill the lightening hole and flange the hole in under 45 minutes per rib. We shall see.
Almost perfect
Almost perfect
Too much metal...too little space
