Brief Description: Completed right #6 rib and both #5 ribs
Before tonight, I had completed only the left wing #6 wing rib. Tonight I completed the other #6 and both #5 ribs. Then I took the plunge and completed trimming and smoothing all remaining rib blanks. Additionally, I trimmed the 1.2mm edge on the top & bottom leading edge of each rib form. This means that all I have to do now is actually bend ribs 1 to 4...without further prep. Finally, I drilled two test 95mm holes and tried flanging my reject #4 rib (first one I made). The flanges came out perfectly. More pictures to follow.
