Larry Winger's 601XL Project
Date:  6-3-2007
Number of Hours:  3.50
Manual Reference:  6W4
Brief Description:  Center spar marked and drilled
I measured and marked my front web then pilot drilled it with the #40 bit, followed by the #30 bit. Next I stacked the front and back webs and back drilled the back web in all locations but the outboard uprights for the dual controls. Then I used the flycutter to produce the 95mm hole in both parts. The last thing tonight was to cut the center spar caps to 1014mm and polish the ends.
Webs stacked & drilled
