Pauls Web Site
Date:  9-6-2017
Number of Hours:  5.00
Brief Description:  Tail surface attachment
I attached the Ailerons and Flaps. As others have had, there was some interference with one of the push rods and a could rib lightening holes at full forward stick position (down elevator). I removed a small amout of material from each offending hole, and filed and sanded smooth from a very uncomfortable position. Good news is that I hadn't installed the bottom skin of the eppenage, otherwise it would have been nearly impossible.
Ailerons and Flaps Attached
